PROBLEMA
Ya no se admite el uso de ArcPy para publicar servicios de imágenes
Last Published: May 6, 2024
Descripción
Any examples using ArcPy for image service publishing were written in Python 2.7. Even though they still work now in Python 3.6, they will not be supported going forward and may actually break with ArcObjects11.
Causa
The new Python 3.6 ArcPy method for publishing image services will not be implemented in the foreseeable future, although a function exists for map services. See: the help topic CreateSharingDraft.
Esri recommends publishing image services programmatically only using JSON and the REST API for ArcGIS Server.
Id. de artículo: 000025490
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
