PROBLEMA
Data Interoperability presenta incompatibilidades cuando hay más de un producto de Data Interoperability en el mismo equipo
Last Published: April 29, 2024
Descripción
When more than one Data Interoperability product is installed on a single machine, there are known issues with the compatibility and functionality of the Data Interoperability installation. Documented in this technical article are a list of install sequences of the Data Interoperability products, the problem that occurs, and the workaround for the issue.
Installed FirstInstalled SecondProblem
ArcGIS Data Interoperability 10.6 for DesktopData Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability 10.6 for Desktop Quick Import/Export dialog script error in MdDlgContent.htm
ArcGIS Data Interoperability 10.6 for DesktopData Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability 10.6 for Desktop Interoperability connections can be created but do not work
Data Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability 10.6 for DesktopData Interoperability for ArcGIS Pro 2.1 Quick Import input dataset picker cannot browse
Data Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability 10.6 for DesktopData Interoperability for ArcGIS Pro 2.1 Quick Export output dataset picker cannot browse
Data Interoperability for ArcGIS Pro 2.1ArcGIS Data Interoperability for Server for 10.6ArcGIS Data Interoperability for Server for 10.6 fails to publish Spatial ETL tools
Causa
Esri is aware of the underlying cause of these issues and is working to get them fixed.
Until a permanent fix for these issues becomes available, Esri recommends the workaround listed below.
First / SecondWorkaround
ArcGIS Data Interoperability 10.6 for Desktop /
Perform a repair install of ArcGIS Data Interoperability 10.6 for Desktop.
Data Interoperability for ArcGIS Pro 2.1 /
Perform a repair install of Data Interoperability for ArcGIS Pro 2.1.
No workaround for side-by side-operation exists. Uninstall ArcGIS Data Interoperability for Server 10.6.
Id. de artículo: 000017667
Obtenga soporte con IA
Empieza a chatear ahora
Descubrir más sobre este tema
Ir a opciones de descarga
