CÓMO
Cambiar el nombre de un servicio publicado en ArcGIS Server
Last Published: July 19, 2023
Resumen
It is not possible to rename a published service in ArcGIS Server Manager, even though the details of the services can be edited directly on ArcGIS Server Manager page. However, it is possible to use the Rename Service operation in the ArcGIS Server Administrator Directory, and the result is reflected in ArcGIS Server Manager. This article provides the steps to rename a published service in the ArcGIS Server Administrator Directory.
Procedimiento
  1. Log in to the ArcGIS Server Administrator Directory as a site administrator.
  2. In the Resources section, click services.
The image of the ArcGIS Server Administrator Directory page that shows services
  1. In the Supported operations section, click renameService.
Image of ArcGIS Server Administrator Directory showing renameService
  1. On the Rename Service page, specify the Service name, Service type, and New Service name fields. In the example below, a published map service titled Assignment1_test is renamed to Assignment1.
Image of the Rename Service page
  1. Click Rename to rename the map service.
The images below show the renamed published service in the ArcGIS Server Administrator Directory and ArcGIS Server Manager.
Image of the renamed map service in ArcGIS Server Administrator Directory
Image of the renamed map service in ArcGIS Server Manager
Alternatively, republish the service with a new name in ArcGIS Server Manager.
Id. de artículo: 000024590
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
