PROBLEMA
El servicio de geoprocesamiento no toma una URL de servicio de imágenes al publicar una herramienta web que toma la URL del servicio de imágenes como entrada
First Published: June 5, 2020
Last Published: May 3, 2024
Descripción
When publishing a web tool from ArcGIS Pro, the geoprocessing service does not take an image service URL or any other input.
Causa
This is due to the configuration in the Input parameter before publishing the service. By default, the Input Mode is a choice list, which only takes layers predefined before publishing the service.
The solution is to configure the content input parameter before publishing the web tool. This can be used for any geoprocessing tool that takes raster as an input.
For this example, we are using Slope.
  1. In ArcGIS Pro project, add a raster to the map and run the geoprocessing tool.
  2. Click Open History, and right-click Slope > Share As > Web Tool.
  1. In the Share As Web Tool pane, provide a name of the service and fill out all the information.
  2. Navigate to Content, and select Configure Tool Properties on the tool.
  1. Under the Slope Properties, change the Input Mode in Input raster parameter to User defined value.
The web tool is now ready to be published.
Id. de artículo: 000023158
Obtenga soporte con IA
Empieza a chatear ahora
Descubrir más sobre este tema
Ir a opciones de descarga
