CÓMO
La georreferenciación de datos CAD implica asignar un sistema de coordenadas y aplicar una transformación a los datos CAD. Las instrucciones proporcionadas describen cómo georreferenciar datos CAD en ArcMap.
Note: ArcMap is in Mature support and will be retired March 1, 2026. There are no plans for future releases of ArcMap, and it is recommended that you migrate to ArcGIS Pro. See Migrate from ArcMap to ArcGIS Pro for more information.
Note: Before georeferencing the CAD data, assign the desired projection to the map to which the CAD data will be referenced. The georeferencing process writes out the projection file for the newly georefenced CAD file.
Refer to FAQ: How do I define the projection for ArcGIS data? for more information.
Note: The CAD World File window displays.
Id. de artículo: 000012808
Empieza a chatear ahora
