CÓMO
When authorizing an enterprise geodatabase on an ArcGIS Server instance, a keycodes file is required to complete the authorization process. As the keycodes file is generated during the authorization process, in some instances, when access to an ArcGIS Server instance is unavailable, the authorization process cannot be completed. For example, when a different machine is used for the authorization, or when the server is unavailable.
Follow the steps below to complete the software authorization process, and generate a new keycodes file to authorize an enterprise geodatabase when an ArcGIS Server instance is unavailable.
Note: An authorization file for ArcGIS Server is still required to perform the following procedure. It is not possible to authorize an enterprise geodatabase if only an ArcGIS Pro or ArcGIS Desktop license is available.
C:\Program Files\ArcGIS\Pro\bin\SoftwareAuthorizationPro.exe
C:\Program Files (x86)\Common Files\ArcGIS\bin
Note: Refer to the ArcGIS Server administrator to determine the correct ECP file.
C:\Program Files\ESRI\License10.x\sysgen
C:\Program Files (x86)\Esri\License10.x\sysgen
Id. de artículo: 000024911
Empieza a chatear ahora
