CÓMO
Exportar campos seleccionados de una tabla de atributos de ArcGIS Pro a Microsoft Excel
Last Published: July 21, 2023
Resumen
Exporting attribute tables from ArcGIS Pro to Microsoft Excel allows for editing, reviewing and saving the data externally. In some cases, editing or re-creating the data requires only certain fields from the attribute table. This article describes the method to export selected fields in an attribute table from ArcGIS Pro to Microsoft Excel.
Procedimiento
  1. In an ArcGIS Pro project, in the Contents pane, select the layer with the attribute table containing the fields to be exported. In this example, the layer is 'Streams'.
  2. On the top ribbon, under Feature Layer, click the Data tab > Fields. The Fields view of the attribute table opens.
The image shows a screenshot showing the user interface on the top ribbon of ArcGIS Pro.
  1. In the Fields: <layer_name> tab, under Visible, check the check boxes of the fields to export.
The screenshot shows the fields view of the Steams layer.
  1. On the top ribbon, click the Fields tab > Save.
The screenshow shows the Save button on the Fields tab.
In the attribute table, only the selected fields are visible and only these are exported in the next step.
  1. Export the selected fields to Microsoft Excel. Use one of the methods in How To: Export an attribute table from ArcGIS Pro to Microsoft Excel.
Id. de artículo: 000024325
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
