CÓMO
Habilitar un grupo de actualizaciones compartidas para editar los registros de encuestas enviados
Last Published: January 30, 2025
Resumen
When receiving submissions from surveys, users can edit these submission records in the ArcGIS Survey123 website. In some instances, it is useful to delegate these tasks to other users for data management purposes. This article provides the workflow on how to enable a shared update group to edit submitted survey records.
Procedimiento
  1. Log in to ArcGIS Online and create a group. Refer to ArcGIS Online: Create a group for instructions.
  2. In the Create a group window, under Group designations, enable the Shared update option.
'Create a group' configuration window in ArcGIS Online.
  1. Click Save.
  2. Log in to the ArcGIS Survey123 website using the same credentials as the ArcGIS Online account.
  3. Browse to and click the survey to view it.
  4. On the survey page, click the Collaborate tab, and click Update Survey.
  5. On the Update survey tab, in the Who can update this survey? section, browse to and check the check box next to the desired shared update group.
  6. Click Save.
The Update Survey tab settings in ArcGIS Survey123.
Id. de artículo: 000028952
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
