CÓMO
Deshabilitar el elemento emergente de estado de la aplicación en ArcGIS Web AppBuilder
Last Published: July 27, 2023
Resumen
When viewing or after refreshing the ArcGIS Web AppBuilder app, the pop-up message, 'Click to restore the map extent and layers visibility where you left off' is displayed at the bottom-right corner by default. In some cases, it is best to disable the pop-up if it is not required.
Image of the App State pop-up
This article provides steps to disable the App State pop-up in ArcGIS Web AppBuilder.
Procedimiento
When the ArcGIS Web AppBuilder app is created, the App state check box is turned on by default. Refer to ArcGIS Web AppBuilder: App state for more information.
  1. Log in to ArcGIS Online or Portal for ArcGIS.
  2. Navigate to Content > My Content.
  3. Browse to the desired Web AppBuilder for ArcGIS app, click More Options Image of the More Options button, and click Edit Application.
Image of the My Content window
  1. On the Attribute tab, under App state, uncheck the Keeps map extent and layers visibility while leaving the app. check box.
Image of the Attribute tab
  1. Click Save to save the app.
The App State pop-up is not displayed when viewing or after refreshing the ArcGIS Web AppBuilder app.
Image of ArcGIS Web AppBuilder
Id. de artículo: 000023449
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
