CÓMO
Crear un formulario de ArcGIS Survey123 de varias páginas
Last Published: March 1, 2024
Resumen
Creating a multiple-page ArcGIS Survey123 form helps to organize a survey into sets of related groups or questions. This creates a more user-friendly experience when answering the survey.
Procedimiento
Follow the instructions below to create a multiple-page form using ArcGIS Survey123 Connect or the Survey123 web designer.
With ArcGIS Survey123 Connect 3.6 and later versions, it is not possible to configure a survey form with multiple tabs.
  1. In Survey123 Connect, create a survey using an Advanced template.
  2. Open the XLSForm. In the settings tab, type pages in the style column.
Type 'pages' in the Style column
  1. In the survey tab, configure groups of questions that start with begin group and end with end group. Refer to ArcGIS Survey123: Group for more information on groups.
  2. In the same row as begin group, navigate to the appearance column, and select field-list from the drop-down list. The field-list appearance separates each group into a different page. The image below shows five groups of survey questions separated into five pages by specifying the appearance column as field-list.
Select field-list
Questions, groups, or repeats that are not specified with field-listappear on all pages.
The images below show the appearance of a multiple-page survey form on various platforms.
  • On the Survey123 Connect Form Preview tab:
Form in the Form Preview page
  • In the Survey123 web form
The form in the web form
  • In the Survey123 field app
The form in the field app
To put multiple groups on a single page, create nested groups (secondary groups within a primary group), and select field-list for the begin group type of the primary group. The image below shows two primary groups, each with two secondary groups.
A form with two primary groups, each with two secondary groups
The image below shows the Form Preview tab of the two groups configured on a single page.
Two groups in a single tab
ArcGIS Survey123 web designer
  1. In the ArcGIS Survey123 web designer, configure the questions for the first page.
  2. To create a new page, click Page in the Add tab.
Click the Page icon
The image below shows the new page and the corresponding Edit tab for the new page.
A new page in web designer
To merge two pages, select the pages, and click either the Merge with the previous page or Merge with the next page icon at the top right corner.
The merge option
Id. de artículo: 000021886
Obtenga soporte con IA
Empieza a chatear ahora
Ir a opciones de descarga
