CÓMO
Configurar un PMF para abrirlo en ArcMap
Resumen
Published Map Files (PMF) can only be opened in ArcReader by default. Changing the options within the ArcGIS Publisher extension allows a PMF to be created so it also opens in ArcMap.
Procedimiento
  1. In ArcMap, enable the Publisher extension.
  2. On the Publisher toolbar, click Publisher > Settings, and click the Application tab.
  3. Under ArcReader, uncheck the Open in ArcReader only check box.
  4. Under ArcGIS Applications, check the Unrestricted access to contents of Published Map check box.
  5. Click OK to close the Publisher Settings dialog box, and publish the map.
The Publisher Settings dialog box with Open in ArcReader only unchecked, and Unrestricted access to contents of Published Map checked.
The modified Publisher settings are only saved within the map document. New map documents revert to the default settings, and require changing the settings each time before publishing the map documents.
The PMF can be opened from ArcMap through the File > Open dialog box. Change the Files of type option to Published Maps (*.pmf) or All Supported Map Formats.
Id. de artículo: 000011615
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
