Preguntas frecuentes
¿Dónde se almacena el archivo de método abreviado de teclado personalizado de ArcGIS Pro en un equipo Windows?
Last Published: May 30, 2024
ArcGIS Pro version 3.2 provides the functionality to create a custom keyboard shortcut. Creating custom keyboard shortcuts simplifies user interface commands by combining keystrokes on a keyboard. For more information on ArcGIS Pro keyboard shortcut utilization, refer to ArcGIS Pro: Use keyboard shortcuts.
On a Windows machine, the ArcGIS Pro custom keyboard shortcut is saved in a .daml file in the AppData local folder. Data, user profiles, and app settings unique to a single Windows machine are stored in the AppData local folder, which is hidden by default. A custom keyboard shortcut is stored in the .daml file in the AppData local folder, as it is an app setting particular to a single ArcGIS Pro user on one Windows system.
In certain circumstances, it may be necessary to copy the custom keyboard shortcuts to other machines. To do this, export the custom keyboard shortcuts. Refer to ArcGIS Pro: Export and import customizations for instructions.
Id. de artículo: 000031820
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
