Preguntas frecuentes
¿Es posible reordenar las columnas de campo de la tabla de atributos de Map Viewer de ArcGIS Online?
First Published: April 8, 2020
Last Published: March 13, 2024
Yes, it is possible to reorder field columns in the attribute table in Map Viewer Classic of ArcGIS Online. Field columns represent attributes of a layer and can be reordered based on the importance or groupings of certain attributes. Use any of the methods below to do so.
From Configure Pop-Up in Map Viewer Classic
This method is applicable for web maps, feature layers, and hosted feature layers.
  1. In ArcGIS Online, open the web map or feature layer in Map Viewer Classic. In this example, a web map named Customers is opened.
  2. In the Contents pane, navigate to the layer, and click the More Options The More Options icon. icon.
  3. Click Configure Pop-Up > Configure Attributes.
  4. In the Configure Attributes dialog box, select the desired attribute to reorder, and click either the Move up or Move down icon. Reorder the attributes according to the desired order. Click OK.
The Configure Attributes icon.
The table below shows the initial and final attributes display, before and after the attributes are reordered for this example.
BeforeAfter
ADDRESSSTOREID
CITYCUSTID
STATEPURCHASE ($)
ZIPADDRESS
PURCHASE ($)CITY
CUSTIDZIP
STOREIDSTATE
  1. In the Configure Pop-up pane, click OK.
The reordered attributes.
  1. Save the map.
For feature layers or hosted feature layers, click the More Options icon, and click Save Layer. This saves the changes to the layer. Skipping this step does not retain the changes made when the feature layer is opened in Map Viewer Classic in a different session.
From the Visualization tab
This method is applicable for feature layers, and hosted feature layers.
  1. In ArcGIS Online, open the item details page of the hosted feature layer. In this example, a hosted feature layer named Volcano_Japan is opened.
  2. Select the Visualization tab, and click the Configure Pop-up icon.
Click the Configure Pop-up icon.
  1. Click Configure Attributes.
  2. In the Configure Attributes dialog box, select the desired attribute to reorder, and click either the Move up or Move down icon. Reorder the attributes as desired. Click OK.
Reorder the fields.
BeforeAfter
NAMENAME
LOCATIONLOCATION
YEARELEVATION
ELEVATIONTYPE
TYPEYEAR
VOLCANIC EXPLOSIVITY INDEXTSUNAMI
EARTHQUAKEEARTHQUAKE
TSUNAMIVOLCANIC EXPLOSIVITY INDEX
  2. Click Save Layer.
Opening the attribute table in Map Viewer Classic shows the attributes are displayed in the configured order.
The configured order.
Id. de artículo: 000022958
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
