Preguntas frecuentes
Yes, it is possible to launch an ArcGIS Pro project from the Command Prompt. The Command Prompt is a command line interpreter application in a text-based user interface screen of an operating system or program. It is used to perform commands entered in the application.
The workflow below describes how to launch an ArcGIS Pro project from the Command Prompt.
"<ProjectDirectory>\<ProjectName>"
Note: Ensure the double quotes are present around the command line to properly execute the command.
"C:\Users\<username>\Documents\ArcGIS\Projects\LabelMapFeatures\Portland Labels.aprx"
Id. de artículo: 000026068
Empieza a chatear ahora
