Preguntas frecuentes
¿Hay tutoriales disponibles para configurar calles de sentido único para la extensión Network Analyst?
First Published: May 5, 2016
Last Published: May 1, 2025
The ArcGIS Network Analyst Tutorial for ArcMap version 10.6 provides an overview of the Oneway restriction attribute and other evaluators in Exercise 2: Creating a multimodal network dataset, Configuring the DriveTime, Oneway, and DrivingAVehicle evaluators.
The attached instructions describe how to add and populate the data needed to enforce one-way travel direction on streets for ArcMap versions 9.x/10.0. Download (right-click the link and click Save link as...) and unzip the data, 'NA_One-way_tutorial.zip', from the Related Links section below.
Id. de artículo: 000008060
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
