ERROR
No se puede cargar KML: Error de analizador KML interno
Mensaje de error
When adding a KML file using the 'From my computer' option to Portal for ArcGIS, the following error message is returned:
Error:
Unable to load KML: Internal kml parser error.
Causa
The error occurs because the script in the KML file is not encoded using UTF-8.
Follow the steps below to encode the script using UTF-8.
  1. Open the KML file in a text editor such as Notepad ++.
  2. Click the Encoding tab and select Convert to UTF-8.
    Encoding tab and UTF- 8 option
  3. Save the file and add to Portal for ArcGIS. For more detailed steps, refer to Portal for ArcGIS Web Help: Add layers from the web .
Id. de artículo: 000018602
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
