CÓMO
The instructions provided describe how to create a custom projection file for CAD data, and how to align the CAD file with other data in a projected coordinate system with units of feet, meters, or other linear units in ArcMap 10.1 and above.
Note: These instructions apply to ArcGIS versions 10.1 through 10.2.2. For 10.0 and previous versions, please see Create a custom projection file in ArcMap to align CAD data.
Note: These instructions cannot be used to align CAD data with data in a Geographic Coordinate System, with units of decimal degrees. Reference data must be in a projected coordinate system with units of feet or meters.
Follow these steps in ArcMap to align a CAD file (AutoCAD DWG or Microstation DGN) with other data by creating a custom projection file.
Note: In the Add Data dialog, navigate to the folder where the CAD data resides on the computer. Double-click the name of the CAD file, and select the Polyline layer to add it to the map.
Note: If the data cannot be seen, right-click the name of the layer in the Table of Contents, and select Zoom to Layer. Drop a Marker symbol from the Drawing toolbar on the data, and zoom to the full extent. Repeat for the reference data if necessary, or if the Marker symbol is not visible.
Note: It is helpful to write down these measurements on a piece of paper with a direction arrow, indicating the direction the CAD data must move to align with the other data.
Note: The new name cannot contain special characters or spaces, but underscores can be used.
Note: Making the False Easting value larger moves the CAD file west. Making the False Easting value smaller moves the CAD data east.
Note: ArcMap calculates coordinate position to 16 significant digits, so the zeros to the right of the decimal must be retained.
Note: It is helpful to write down these values, with a direction arrow.
Note: Making the False Northing larger moves the data south. Making the False Northing smaller moves the data north.
Note: Once the projection file is added to the Favorites folder, it cannot be added again unless the file name is changed. Appending an _1, _2, etc., serves this purpose.
Repeat these steps as needed, making incremental adjustments to the False Easting and False Northing, until the alignment of the CAD polylines to the reference data is the best possible result.
Note: Keep in mind: The CAD data may not align exactly with the available reference data, because of inaccuracies in one or both sets of data.
C:\Users\<user profile>\AppData\Roaming\ESRI\Desktop10.x\ArcMap\Coordinate Systems
Note: If the AppData folder is not visible, ensure 'Show hidden files, folders, and drives' is checked in Folder Options.
Note: If multiple CAD files in the same local coordinate system are stored in the folder, the custom projection file named 'esri_CAD.prj' will define the projection for ALL the CAD files in the same folder.
The next time the CAD file is added to ArcMap, the software recognizes the projection definition, and is able to project the data on-the-fly, along with any other data in the map.
Note: Three chapters in the book titled 'Lining Up Data in ArcGIS: A Guide to Map Projections, Second Edition' are devoted to detailed instructions for this process, and address such questions as identifying custom units, or creating a custom projection file for rotated CAD data, which are too technical to address in this article. For additional assistance, contact Esri Support Services on the web, or by phone at 888-377-4575.
Id. de artículo: 000012038
Empieza a chatear ahora
