PROBLEMA
Error de excepción de Python "número mágico incorrecto en 'requests.packages': b'\x03\xf3"
Last Published: April 16, 2024
Descripción
In some scenarios, such as calling a Data Interoperability Spatial ETL Tool from a Python script, the following error is returned:
bad magic number in 'requests.packages': b'\x03\xf3
The "magic number" comes from UNIX-type systems where the first few bytes of a file held a marker indicating the file type. Python puts a similar marker into its pyc files when it creates them. The Python interpreter ensures that this number is correct when loading the file.
Causa
Anything that damages this magic number will cause the error. This includes editing the .pyc file or trying to run a .pyc file from a different version of Python (usually later) than your interpreter.
  1. If the issue is with your .pyc files, delete them and let the interpreter re-compile the .py files. On UNIX-type systems, that could be something as simple as:
rm *.pyc
or:
find . -name '*.pyc' -delet
  1. Uninstall the Data Interoperability extension.
  2. Reinstall the correct version of Python.
  3. Reinstall Data Interoperability.
Id. de artículo: 000025627
Obtenga soporte con IA
Empieza a chatear ahora
Descubrir más sobre este tema
Ir a opciones de descarga
