PROBLEM
When a legend is added to a layout, the overflow symbol is displayed, and the legend text items are partially displayed in ArcGIS Pro.
This is by design. The legend text items are set to word wrap by default, causing the overflow symbol to display and the legend text items to partially display on the legend. This happens when the text items are too long and exceed the legend space.
Use one of the following methods to resolve the issue.
Configure the word wrapping settings
The image below shows the overflow symbol no longer displays on the legend.
Change the feature layer's name
Changing the feature layer's name in the Contents pane reflects changes in the legend. Follow the workaround below to change the feature layer's name.
Get help from ArcGIS experts
Download the Esri Support App
