HOW TO
In ArcGIS Pro, changing the unit of graticule labels does not reflect any change in the layout. This is because configuring the unit using the Menu button only controls the input options for longitudes and latitudes in the Element pane, as shown in the image below.
This article describes the workflow to change the unit of labels for the longitudes and latitudes of a graticule in ArcGIS Pro.
Note: Replace 'dms' with 'ddm' to change the unit to Degrees Decimal Minutes. Refer to ArcGIS Pro: Map frame tags for more information.
The image below shows the unit of graticule labels in Decimal Degrees.
Article ID: 000028941
Get help from ArcGIS experts
Download the Esri Support App
