PROBLEM
In ArcGIS Pro, when copying and pasting images from layouts of a project to other layouts of other projects, the images are not visible, although the paths are retained in the Element pane as shown below.
Depending on the cause, use one of the options below to resolve the issue.
Locate the pasted image manually
Restart ArcGIS Pro
Close the current session of ArcGIS Pro, and restart the local machine.
Repair ArcGIS Pro
Use ArcGIS Pro 2.9 or earlier
Warning: The instructions below include making changes to essential parts of the operating system. Esri recommends performing a backup of the operating system and files, including the registry, before proceeding. Esri cannot guarantee results from incorrect modifications while following these instructions. Exercise caution. Consult a qualified computer systems professional if necessary.
Alternatively, downgrade ArcGIS Pro to version 2.9 or earlier if necessary. Perform a clean uninstall by referring to Esri Australia Technical Blog: Performing a clean uninstall of ArcGIS Pro . After performing a clean uninstall, download and install ArcGIS Pro 2.9 or earlier.
The image below shows the copied image is pasted into the layout.
Get help from ArcGIS experts
Download the Esri Support App
