PROBLEM
In ArcGIS Pro, attempting to select features in a map using the Select Layer By Attribute tool returns the opposite records of the query.
In this example, the query in the Select Layer By Attribute tool is to select the layer with the OBJECTID that equals to 12. However, the selected layers are those with the OBJECTID that do not equal to 12, as shown in the image below.
The Invert Where Clause option is enabled in the Select Layer By Attribute tool. Thus, running the tool returns the inverse results of the query.
To solve the issue, ensure the Invert Where Clause option is disabled before running the Select Layer By Attribute tool. Refer to ArcGIS Pro: Parameters for more information on the Select Layer By Attribute tool.
Alternatively, once the opposite record of the query is selected, use Switch Selection in the attribute table to deselect all the selected features and select all the deselected ones. In the Contents pane, right-click the feature layer, navigate to Selection, and click Switch Selection.
Article ID: 000028570
Get help from ArcGIS experts
Start chatting now
