HOW TO
In ArcGIS Business Analyst, geographic boundaries can be selected to create a site to represent areas of interest. The description of the geographic boundary can be viewed on the pop-up by clicking on the boundary.
By default, once the geographic boundaries are selected and added to the map, the description of these boundaries are labelled according to the geographic boundary type from the list in the ‘Select From Map’ option. However, in ArcGIS Business Analyst, there is no option to edit the description of the geographic boundaries. In this example, the image below shows the ZIP Code is used by default as the description for the selected geographic boundary.
This article describes how to edit the description of custom geographic boundaries in ArcGIS Business Analyst using ArcGIS Online.
Note: The content is saved to ArcGIS Online as a web map and a hosted feature layer.
Note: In the project pane, uncheck all unused layers to allow the new web map's pop-up to display in the map.
The edited description of the geographic boundary can be viewed on the pop-up under Attributes after clicking on the boundary as shown in the image below.
Get help from ArcGIS experts
Download the Esri Support App
