PROBLEM
When attempting to configure forms in the ArcGIS Field Maps web app, the feature layer is disabled in the Content page as shown in the image below.
Depending on the cause, use one of the following options to resolve the issue.
Enable the editing capabilities of the hosted feature layer in ArcGIS Online
Log in to ArcGIS Online with the same credentials used in ArcGIS Field Maps, and check the Enable editing check box in the hosted feature layer settings. Refer to ArcGIS Online: Settings that control editing access for instructions.
Publish the feature layer as a hosted feature layer in ArcGIS Online
Note: Step 3 is not required for non-hosted feature layers added to the map through the Search for Layers option.
Ungroup the sublayer under the group layer in Map Viewer
In ArcGIS Online, browse to the web map, and ungroup the sublayer under the group layer in Map Viewer. Refer to ArcGIS Online: Create and manage group layers for more information.
The image below shows the hosted feature layer’s form available to be configured in the ArcGIS Field Maps web app.
Article ID: 000028112
Get help from ArcGIS experts
Download the Esri Support App
