HOW TO
In ArcGIS StoryMaps, embedding videos can make a story more visually engaging and enrich the user experience. However, an embedded video link does not play automatically in ArcGIS StoryMaps.
The image below shows only the video link after embedding the URL in the story map.
This article highlights the workflow to enable autoplay on the video using an iframe code and the video's embed URL in ArcGIS StoryMaps.
Note: To use any third-party URL parameters, add the video using the embed URL. Only the 'src' parameter is required in the embed code. The other parameters can be deleted.
The following code block demonstrates the full script.
<iframe src="Third-party embed URL?autoplay=1&loop=1&autopause=0&background=1&mute=1" height="400" width="800"></iframe>
The video autoplays when scrolled to in ArcGIS StoryMaps.
Article ID: 000028057
Get help from ArcGIS experts
Download the Esri Support App
