HOW TO
ArcGIS Pro allows splitting a polygon feature into several segments by using tools such as the Split (Analysis) tool and the Split tool from the Modify Features pane. However, the tools provided are unable to split the polygon by percentage. Follow the steps provided in this article to split a polygon by percentage in the Python window.
Import arcpy p = arcpy.mp.ArcGISProject("CURRENT") m = p.listMaps("<Map_Name>")[0] lyr = m.listLayers(0)
splits = [20, 30, 50]
with arcpy.da.SearchCursor("<Layer_Name>", ["SHAPE@"]) as pcursor: for prow in pcursor: polygon = prow[0] # polygon to cut e = polygon.extent # bounding extent of polygon print(e.XMin,e.YMin,e.XMax,e.YMax) del pcursor
stepsize = 0.001
leftXstart = e.XMin leftX = e.XMin + stepsize ymax = e.YMax ymin = e.YMin
cutpoly = polygon icursor = arcpy.da.InsertCursor("<Layer_Name>", ["SHAPE@"]) for i in splits[:2]: print(i) tol = 0 while tol < i: # construct NS line pntarray = arcpy.Array() pntarray.add(arcpy.Point(leftX, ymax)) pntarray.add(arcpy.Point(leftX, ymin)) pline = arcpy.Polyline(pntarray,arcpy.SpatialReference(<WKID>)) # cut polygon and get split-parts cutlist = cutpoly.cut(pline) tol = 100 * cutlist[1].area / polygon.area leftX += stepsize #print str(leftX) + ":" + str(tol) cutpoly = cutlist[0] icursor.insertRow([cutlist[1]]) # part 0 is on the right and part 1 is on the left of the split
icursor.insertRow([cutlist[0]]) del icursor
The code below shows the full working script.
Import arcpy p = arcpy.mp.ArcGISProject("CURRENT") m = p.listMaps("Map")[0] lyr = m.listLayers(0) splits = [20, 30, 50] with arcpy.da.SearchCursor("testpolygon", ["SHAPE@"]) as pcursor: for prow in pcursor: polygon = prow[0] e = polygon.extent print(e.XMin,e.YMin,e.XMax,e.YMax) del pcursor stepsize = 0.001 leftXstart = e.XMin leftX = e.XMin + stepsize ymax = e.YMax ymin = e.YMin cutpoly = polygon icursor = arcpy.da.InsertCursor("testpolygon", ["SHAPE@"]) for i in splits[:2]: print(i) tol = 0 while tol < i: pntarray = arcpy.Array() pntarray.add(arcpy.Point(leftX, ymax)) pntarray.add(arcpy.Point(leftX, ymin)) pline = arcpy.Polyline(pntarray,arcpy.SpatialReference(3857)) cutlist = cutpoly.cut(pline) tol = 100 * cutlist[1].area / polygon.area leftX += stepsize cutpoly = cutlist[0] icursor.insertRow([cutlist[1]]) icursor.insertRow([cutlist[0]]) del icursor
The image below demonstrates the polygon split by 20%, 30%, and 50% after running the Python script in ArcGIS Pro.
Get help from ArcGIS experts
Download the Esri Support App
