HOW TO
In ArcGIS Pro, a north arrow in a layout represents the orientation of the map and maintains a connection to the map frame. The default color of a north arrow in ArcGIS Pro is black and white, as shown in the image below.
In some instances, it is necessary to change the color of the north arrow to enhance the map's visual. This article describes the workflow to change the color of a north arrow in ArcGIS Pro.
Note: This workflow applies to ArcGIS Pro 3.0 and above, and may or may not work in ArcGIS Pro 2.x due to changes to the UI. Refer to ArcGIS Pro: Migration from ArcGIS Pro 2.x to 3.0 for more information on the changes in ArcGIS Pro 3.0.
The image below shows the color of the north arrow changed in ArcGIS Pro.
Article ID: 000027945
Get help from ArcGIS experts
Download the Esri Support App
