ERROR
ValueError: could not convert string to float: '<string>'
Last Published: July 5, 2022
Error Message
When running the Train Deep Learning Model tool in ArcGIS Pro, the following error message is returned:
Error:
The Train Deep Learning Model (Image Analyst Tools) error message window.
Cause
The error message is returned when the numeric values used in the ArcGIS Pro Train Deep Learning Model tool include a comma instead of a decimal point as the decimal delimiter.
ArcGIS Pro Deep Learning tools, including the Export Training Data For Deep Learning tool, use the Windows regional settings to export or train data. Python scripts only expect a decimal point to be the decimal delimiter, and assume numeric values with a comma to be strings. Therefore, regional or language settings that use a comma in the numeric values cause the tool to fail and return the error message.
Solution or Workaround
  1. Change the number formats in the Windows regional settings. Refer to Microsoft Support: Change the Windows regional settings to modify the appearance of some data types for instructions.
  2. For Decimal symbol, select the decimal point option from the drop-down and click OK.
Decimal point option is selected for the Decimal symbol in the Customize Format window.
  1. Restart the computer to apply the changes.
  2. Re-export the training samples using the Export Training Data For Deep Learning tool.
If necessary, change the Windows display language settings to English (United States). Refer to Microsoft Support: Manage display language settings in Windows for instructions.
Article ID:000027802
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
