PROBLEM
In ArcGIS Pro, the Maplex Label Engine is the default label engine controlling how labels are oriented and placed in a map. It also provides label-placement options for features such as streets, contour lines, and land parcels. In some cases, the labels do not dynamically adjust to the display, but are scaled according to the map extent when the map extent is changed. The label size is reduced as the map is zoomed out to a larger scale.
A reference scale is set for the map, causing the label size to be scaled according to the map extent. To ensure labels are not scaled and are dynamically adjusted to the same display when zooming in or out of the map, the 'Reference scale' must be set to <None>.
Set the 'Reference scale' to <None>.
Article ID: 000027749
Get help from ArcGIS experts
Download the Esri Support App
