ERROR
The relational datastore backup failed. The database backup files were not created
Last Published: May 26, 2022
Error Message
When attempting to connect a new standby data store to an ArcGIS Enterprise site, the process fails, and returns the following error:
Error:
The relational datastore backup failed. The database backup files were not created.
The standby data store log file displays the following error:
Error:
pg_basebackup: could not write file "<standby_data_store_installation_directory>\arcgis\arcgisdatastore\pgdata\base\<folder_name>\<file_name>": No space left on device
Cause
The ArcGIS Data Store installation directory does not have enough drive space.
Solution or Workaround
Remove old backup files from the ArcGIS Data Store directory, or allocate more space to the ArcGIS Data Store directory drive. The default directory for ArcGIS Data Store is:
C:\arcgis\arcgisdatastore
This process must be performed by the organization's IT.
Article ID:000027726
Software:
  • ArcGIS Data Store
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
