Be The First To Get Support Updates
Want to know about the latest technical content and software updates?
How To: Create a list, pie chart, and serial chart with only distinct features from a table in ArcGIS Dashboards
Summary
In ArcGIS Dashboards, Arcade expressions can be used to customize how the data points render for the list, and pie chart elements. Depending on how the element is configured, a data point can represent a feature or a summary statistic.
This article provides the steps to generate distinct features from a table and display them in a list, pie chart, and serial chart for better clarity. The image below displays a list and a pie chart of incidents by condition.
Procedure
- Open the ArcGIS Dashboards item. Click Add element on the dashboard toolbar and place an element in the dashboard.
- Select List for creating a new list, Pie chart for creating a new pie chart, or Serial chart for creating a new serial chart, and click New data expression.
- Specify the following Arcade expression in the Expression window.
- Arcade expression for the list element:
var portal = Portal('<portal_URL>'); var <variableName1> = '<itemID>'; var <variableName2> = FeatureSetByPortalItem( portal, <variableName1>, <sublayer_ID>, ['<field_name_1>', '<field_name_2>', ..., '<field_name_n>'], false); return distinct(<variableName3>, '<field_name_n>')
- Arcade expression for the pie chart, and serial chart element:
var portal = Portal('<portal_URL>'); var <variableName1> = '<itemID>'; var <variableName2> = FeatureSetByPortalItem( portal, <variableName1>, <sublayer_ID>, ['<field_name_1>', '<field_name_2>', ..., '<field_name_n>'], false) var <variableName4> = GroupBy(<variableName3>, distinct(['<field_name_n>']), [{ name: '<field_name_new>', expression: '<field_name_n>', statistic: '<statistic type>' }]) return <variableName4>
Note: Specifying the fields and includeGeometry parameters in the FeatureSet are optional expressions for the FeatureSetByPortalItem() function. Refer to ArcGIS Arcade: FeatureSetByPortalItem for more information.
- Click Test and review the results below the Expression window.
- Specify a name for the expression and click Done.
- Generate and format the list or pie chart as required. Refer to ArcGIS Dashboards: List, ArcGIS Dashboards: Pie chart, or ArcGIS Dashboards: Serial chart for more information. Click Done.
Related Information
- ArcGIS Dashboards: Dashboard layout
- ArcGIS Dashboards: Add elements
- ArcGIS Dashboards: Arcade in dashboards
- ArcGIS Dashboards: Create a data expression
Last Published: 6/21/2022
Article ID: 000027717
Software: ArcGIS Dashboards 9.4, 9.3, 9.2, 9.1, 10.2, 10.1 ArcGIS Online Current
