PROBLEM
The location of mobile workers is tracked and recorded using ArcGIS Field Maps. Despite having ‘Location sharing’ enabled by the organization and the ArcGIS Tracker add-on license assigned, at times, the My Tracks map card toggle button is disabled and the message ‘Sharing is Unavailable’ is displayed upon launching ArcGIS Field Maps, as shown in the image below.
Change the role of the user with the privilege to share the location
Note: Only default administrators and custom roles with administrator privileges can perform the following workflow.
In ArcGIS Online, change the user’s role to User, Publisher, or Administrator. Refer to ArcGIS Online: Roles and ArcGIS Online: Change member roles for further instructions.
Enable 'View location tracks' for the member's custom role
Enable ‘View content shared with organization’ for the member’s custom role
The message 'Location Sharing Off' is displayed and location sharing can now be enabled in ArcGIS Field Maps.
Get help from ArcGIS experts
Download the Esri Support App
