HOW TO
Arcade expressions can be used in ArcGIS Dashboards to customize how the data points appear in the list, indicator, and table elements. A data point can represent a feature or a summary statistic, depending on how the element is set up. A single data point represents a single feature when using features, and each data point represents the result of a statistic when it is used.
This article provides the steps to color code the background of the List element in ArcGIS Dashboards. In this example, the field values in the Project Status field are referenced to determine the background color for each field value in the Route Name field.
// Edit the desired color accordingly var <variableName> = Decode($datapoint["<variable>"], '<Field value 1>', 'red', '<Field value 2>', 'orange', '<Field value 3>', 'yellow', '<Field value 4>', 'green', '') return { backgroundColor: <variableName> }
The image below shows the list element without the Arcade expression.
The image below shows the list element with the Arcade expression.
Article ID: 000027436
Get help from ArcGIS experts
Download the Esri Support App
