PROBLEM
In ArcGIS Pro, sorting the coded value domain (code or description) in the Domains view and checking the 'Save sorted order' check box fails to retain the new order. Clicking Save after checking the 'Save sorted order' check box returns the original order of the coded value domain.
The image below shows the code values are sorted in ascending order and the 'Save sorted order' box is checked.
The image below shows the original order of the code values is returned after clicking Save.
This is by design. The 'Save sorted order' option does not retain the modified coded value domain order in the Domains view.
To sort the code or description of a coded value domain in either ascending or descending order, use the Sort Coded Value Domain tool.
The sorted coded value domain is reflected in the attribute table when selecting the code values from the drop-down list of the field assigned to the domain.
Article ID: 000027179
Get help from ArcGIS experts
Download the Esri Support App
