PROBLEM
The Download data option is unavailable in ArcGIS Dashboards
Last Published: March 17, 2022
In ArcGIS Dashboards, viewers can download data from a data-driven element in dashboards by clicking the Download data option at the bottom of the element. However, in some cases, the Download data option is not available, as shown in the image below.
The ArcGIS Dashboards window showing the Download data option not available.
Cause
  • The option to download the data of the element is not enabled.
  • The option to export the hosted feature layer to other formats is not enabled. Data download is only available for elements that have a data source with the Export Data setting enabled. Refer to ArcGIS Dashboards: Requirements for more information.
  • The dashboard is accessed by an anonymous user (not signed in to ArcGIS Online).
Solution or Workaround
Depending on the cause, choose one of the workarounds below.
Enable the option to download the data element in ArcGIS Dashboards
  1. Log in to ArcGIS Online. Click Content > My Content.
  2. Browse to the dashboard, click More Options The More Options icon., and select Edit Dashboard.
  3. In ArcGIS Dashboards, hover over the top-left corner of the element, click Options and select Configure. In this example, the List element is configured.
The Layout pane in ArcGIS Dashboards showing the Configure option.
  1. In the List window, on the General tab, scroll down to Data download and enable the Allow download option.
  2. Click Done.
The General tab with the Data download section.
Enable the option to export the hosted feature layer to other formats
  1. In ArcGIS Online, on the hosted feature layer’s item details page, check the Allow others to export to different formats. check box. Refer to ArcGIS Online: Allow data exports for more information.
The Export Data section with the option to export the hosted feature layer.
  1. In ArcGIS Dashboards, follow Steps 3 through 5 from the above method to enable the option to download the data element.
The image below shows the Download data option displayed at the bottom of the element in ArcGIS Dashboards.
The ArcGIS Dashboards window showing the Download data option.
Sign in to ArcGIS Online
Users must be signed in to ArcGIS Online with a member account of the organization that owns the data shared via the public dashboard to access the Download data option.
When data download is enabled, data can only be downloaded by users who are signed in to an ArcGIS Online account. For dashboards shared publicly that include elements with data download enabled, anonymous users do not see the Download data option on the element.
Article ID:000027172
Software:
  • ArcGIS Online
  • ArcGIS Dashboards
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
