Frequently asked question
No, it is not possible to install multiple versions of ArcGIS Pro on the same machine. Only one version of ArcGIS Pro can be installed on the machine at a time. To install a different version of ArcGIS Pro, uninstall the existing version and reinstall a different version.
Note: If the reinstalled version of ArcGIS Pro is lower than the previous version, there may be backward compatibility issues for certain project files. For example, certain files created in a higher version of ArcGIS Pro may not work in a lower version.
Get help from ArcGIS experts
Download the Esri Support App
