PROBLEM
A datum transformation validation warning message is returned when running the ProjectZ tool in ArcGIS Pro
Last Published: December 2, 2021
The ProjectZ tool is designed to transform the collected GPS latitude, longitude, and altitude values into 3D points as well as convert altitude (height above ellipsoid) values into elevation values. When transforming the vertical datum, the following error message is returned:
WARNING:
0001837: Cannot validate datum transformation.
Warning 0001837
Cause
Solution or Workaround
Install ArcGIS Coordinate Systems Data for ArcGIS Pro
  1. Navigate to the My Esri website and log in with the organization credentials.
  2. Select My Organizations > Downloads.
  3. Under Core Products, click View Downloads for ArcGIS Pro.
Click View Downloads for ArcGIS Pro to view all downloadable files for ArcGIS Pro.
  1. Click Expand/Collapse All.
  2. Under Data and Content, search for ArcGIS Coordinate Systems Data for ArcGIS Pro Per User Install and click Download.
Click Download to download and install the ArcGIS Coordinate Systems Data for ArcGIS Pro Per User Install executable file.
Article ID:000026751
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 8 x
  • Other
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
