PROBLEM
In some instances, when using the Browse function in the Merge tool to search for and add input datasets from the local computer file location, null values are returned in the merged results.
The image below shows null values are returned in the attribute table after running the Merge tool.
This is a known limitation of the Merge tool in ArcGIS Pro.
Use one of the methods below to resolve the issue.
Select the input datasets from the drop-down list
Note: Alternatively, drag the datasets from the Contents pane, and drop them in the Input Datasets section in the Merge pane.
Note: Alternatively, click the Reset button after adding feature classes and before running the Merge tool.
The image below shows the correct values are returned in the attribute table after running the Merge tool.
Use the Append tool
In ArcGIS Pro, use the Append (Data Management) tool to resolve the issue. Refer to ArcGIS Pro: Append (Data Management) for more information.
Get help from ArcGIS experts
Download the Esri Support App
