PROBLEM
The REST endpoint can access every GIS Service published on ArcGIS Server using the following URL:
http://<host name>/arcgis/rest/<ServiceName>
In some instances, changing the ArcGIS Server server account causes the REST endpoint to be inaccessible.
The new ArcGIS Server account lacks the necessary permissions to the ArcGIS Server folders.
After changing the ArcGIS Server account, provide permissions for the new ArcGIS Server account to the ArcGIS Server folders in the following directories:
C:\Program Files\arcgis\server\ C:\Program Files\arcgis\server\framework\ C:\Program Files\arcgis\server\usr\ C:\Program Files\arcgis\server\bin\ C:\Program Files\arcgis\server\XMLSchema\ C:\Program Files\arcgis\server\DatabaseSupport\ C:\arcgisserver\ (or where the config-store and directories are located)
Follow these steps to provide permission for the ArcGIS Server folders:
Note: Completing this workaround may require assistance from the organization's IT department.
Article ID:000026603
Get help from ArcGIS experts
Download the Esri Support App
