HOW TO
Export a feature class to feature class or shapefile in a different coordinate system
Last Published: November 23, 2023
Summary
Exporting data allows sharing of data with other users across multiple platforms. In ArcGIS Pro, it is possible to export feature classes to feature classes or shapefiles in a desired coordinate system. This article outlines four methods to do so. These methods include using one of the following analysis tools:
  • The Project tool
  • The Export Features tool
  • The Feature Class To Feature Class tool
  • The Feature Class To Shapefile tool
For more information about these tools, see the Related Information section below.
Procedure
In these examples, the output coordinate system is NAD 1983 HARN StatePlane Washington North FIPS 4601 (US Feet).
Export the feature class to feature class using the Project tool
  1. Open the ArcGIS Pro project.
  2. On the top ribbon, click the Analysis tab > Tools.
  3. In the Geoprocessing pane, search for and click Project (Data Management Tools). The Project window opens.
  4. In the Project window, click Parameters.
  5. Click the drop-down menu of Input Dataset or Feature Class, and select the desired feature layer. In this example, the layer is Washington_Counties.
  6. For Output Dataset or Feature Class, specify a name for the output layer and its location. In this example, the output name is Washington_Counties_Project.
  7. For Output Coordinate System, select a desired coordinate system. In this example, NAD 1983 HARN StatePlane Washington North FIPS 4601 (US Feet) under Projected Coordinate System in the Coordinate System window is selected.
  8. Click Run.
The Project tool window displaying the Input Dataset or Feature Class, Output Dataset or Feature Class and Output Coordinate System parameters.
Export the feature class to feature class using the Export Features tool
  2. On the Contents pane, right-click the desired feature layer. Click Data > Export Features. The Export Features window opens.
  3. In the Export Features window, under Parameters, for the Output Name section, specify the output name. The Input Features and Output Location parameters are populated automatically.
The Export Features window displaying the Input Features, Output Location and Output Name parameters.
  1. In the Export Features window, click Environments.
  2. For Output Coordinate System, select a desired coordinate system. In this example, NAD 1983 HARN StatePlane Washington North FIPS 4601 (US Feet) under Projected Coordinate System in the Coordinate System window is selected.
  3. Leave other parameters at default.
  4. Click OK.
The Export Features window displaying the Output Coordinate System parameter.
Export the feature class using the Feature Class To Feature Class tool
  2. On the top ribbon, click the Analysis tab, and click Tools.
  3. In the Geoprocessing pane, search for and click Feature Class To Feature Class (Conversion Tools). The Feature Class To Feature Class window opens.
  4. In the Feature Class To Feature Class window, click Parameters.
  5. For Input Features, select the desired layer. In this example, the layer is Washington_Counties.
  6. For Output Location, specify the geodatabase location of the layer.
  7. For Output Name, specify a name for the output feature class. In this example, the output name is Washington_Counties_ExportFC.
The Feature Class To Feature Class tool window displaying the Input Features, Output Location, and Output Name parameters.
  1. In the Feature Class To Feature Class window, click Environments.
  4. Click Run.
The Feature Class To Feature Class tool window displaying the Output Coordinate System parameter.
Export the feature class to shapefile using the Feature Class To Shapefile tool
  3. In the Geoprocessing pane, search for and click Feature Class To Shapefile (Conversion Tools).
  4. For Input Features, select the desired layer. In this example, the layer is Washington_Counties.
  5. For Output Folder, specify the folder location for the shapefile. In this example, the folder is Shapefile_Output.
The Feature Class To Shapefile window displaying the Input Features and Output Folder parameters.
  1. In the Feature Class To Shapefile window, click Environments.
  4. Click Run.
The Feature Class To Shapefile window displaying the Output Coordinate System parameter.
Article ID:000026350
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Download the Esri Support App
Get help from ArcGIS experts
Contact technical support
Go to download options
