PROBLEM
When attempting to view or edit submitted records on the ArcGIS Survey123 website, some fields are not displayed in the survey table on the Data tab. However, when clicking the record in the table, the field is displayed on the side panel. In the example below, the field titled Country is displayed on the side panel but not in the survey table.
The Country field is displayed on the survey’s hosted feature layer Data tab in ArcGIS Online.
The field’s visibility is not enabled in the survey table on the ArcGIS Survey123 website. The field settings in ArcGIS Online do not affect the field visibility in the survey table.
Perform the following steps to enable the field's visibility in the survey table on the ArcGIS Survey123 website.
Note: Resize the survey table or field header to display the survey records if the records are hidden due to long field names.
Get help from ArcGIS experts
Download the Esri Support App
