Frequently asked question
Is it possible to copy and paste selected features from a map to a layout in ArcGIS Pro?
Last Published: August 26, 2021
Answer
A layout is a composition of one or more maps, along with supporting elements such as a title, a legend, and descriptive text. After adding a layout to ArcGIS Pro, when working with maps and other elements in the layout, users may want to copy selected features from a map and paste them to the layout. However, the map layer containing the selected features are not added to the layout. Instead, the pasted features are changed to text format, as shown in the image below.
The layout in ArcGIS Pro displaying the pasted features that become text.
As a workaround, export the selected features to a new layer, and add the map frame containing the layer to the layout.
  1. In ArcGIS Pro, select the features from the map. Refer to ArcGIS Pro: Select features interactively for instructions.
The Washington Counties map displaying the highlighted and selected counties.
  1. Export the selected features to a new layer.
    1. On the Contents pane, right-click the layer containing the selected features. Click Data > Export Features.
The Contents pane displaying the layer with selected features. Right-clicking the layer displays the Data and Export Features option.
  1. In the Export Features window, for the Output Name section, specify the output name. The Input Features and Output Location parameters are populated automatically. Click OK.
The Export Features window displaying the Input Features, Output Location and Output Name parameters.
  1. Add the map frame containing the output layer from Step 2 to the layout.
    1. On the Contents pane, check the layer with the features to be added and displayed in the layout.
The Contents pane displaying the checked layer. Only the selected features are displayed on the map.
  1. Click the desired Layout view tab to activate the Layout view. The tab turns blue when it is activated.
  2. On the top ribbon, click the Insert tab, and click Map Frame. In the Map Frame drop-down menu, select the map containing the selected features from Step 1.
The layers in the Map Frame drop-down menu selected to be added to the layout.
The following image displays the layout with the selected features from the map.
The layout displaying the added map with the selected features.
Article ID:000026318
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
