HOW TO
Modify legend labels for the Counts and Amounts symbology in ArcGIS Map Viewer Classic
Last Published: September 28, 2021
Summary
Symbology labels and layer titles are created automatically in the legend based on the selected attributes and layer names, respectively. In some instances, the default symbology labels and layer titles may not indicate the intended information in the legend. For such cases, the layer tiles can be edited to create an informative legend for the web map.
This article describes the steps to change the labels for the Counts and Amounts symbology in ArcGIS Map Viewer Classic.
Procedure
The following steps utilize the Change Style option. This option is only available for supported layers. Refer to ArcGIS Online: Supported layer types for more information.
  1. In ArcGIS Online Map Viewer Classic, add the desired feature layer to the map.
  2. In the Content pane, select the Change Style option.
The Content pane showing the Change Style option
  1. In the Change Style pane, under Select a drawing style, select Counts and Amounts (Color). Click OPTIONS.
The Change Style pane to select Counts and Amounts
  1. Check the Classify Data check box, and click Legend.
The option to check Classify Data
  1. Select the categories, and enter the name(s). Click OK.
The image below shows the modified labels in the Counts and Amounts symbology in ArcGIS Map Viewer Classic.
The modified labels in Counts and Amounts symbology
Article ID:000026208
Software:
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
