ERROR
Unable to log in using IDP. Invalid subject found in SAML response for Shibboleth
Last Published: July 22, 2021
Error Message
When using the Shibboleth IDP, the following error is returned when trying to log in to an ArcGIS Enterprise portal via SAML logins:
Unable to login using Idp. Invalid subject found in SAML response.
Cause
The SAML NameID attribute is missing from the <Subject> element of the SAML assertion response.
Solution or Workaround
  1. Edit the SHIBBOLETH_HOME/conf/saml-nameid.xml file and replace this section:
<bean parent="shibboleth.SAML2AttributeSourcedGenerator"
   p:format="urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress"
   p:attributeSourceIds="#{ {'mail'} }" />
with the following:
            p:format="urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified"
            p:attributeSourceIds="#{ {'your-name-id-attribute'} }" />
  1. Restart the Shibboleth daemon (Linux) or service (Windows).
Article ID:000026099
Software:
  • Portal for ArcGIS
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
