PROBLEM
When attempting to access a service in ArcGIS Server, the operation may fail. ArcGIS Server CPU usage increases to 100%, and the ArcGIS Server machine may fail intermittently. The log files display the following error messages:
Error: 32905 - <Msg time="date_time" type="INFO" code="9029" source="Rest" process="20788" thread="1" methodName="" machine="machine_name" user="" elapsed="" requestID="request_ID">Request user: username, Service: Hosted/service_name/FeatureServer</Msg> 32954 - <Msg time="date_time" type="WARNING" code="9003" source="Rest" process="20788" thread="1" methodName="" machine="machine_name" user="" elapsed="" requestID="request_ID">Unable to process request. Java heap space</Msg>
The error message preceding the Java heap space error notifies the user which service is causing the performance issue in ArcGIS Server.
The Java heap size for the service is not large enough. The heap size setting controls the maximum file size a client can provide, and a service with a small heap size may not be able to handle large requests, causing performance issues within ArcGIS Server.
Get help from ArcGIS experts
Download the Esri Support App
