PROBLEM
In some instances, after editing vertices on feature layers, the edits are not saved in ArcGIS Pro.
The issue occurs when the edited layer is projected using a different coordinate system from the map. When adding a new map, the default coordinate system is WGS84 Web Mercator. If the geographic coordinate system of the map and the layer differ, edits to a feature or vertices on the feature layer are not saved in ArcGIS Pro.
Choose one of the methods below to save the edited vertices.
Change the coordinate system of the feature layer using the Define Projection tool
Note: Ensure the desired layers are not active when using the Define Projection tool.
Export the features using the Export Features option
The following image shows the vertices are editable in the feature layer.
Article ID: 000026007
Get help from ArcGIS experts
Download the Esri Support App
