HOW TO
The Select widget, available in Web AppBuilder for Developers 2.1 and later, as well as the ArcGIS Online Web AppBuilder, provides the useful functionality to make a selection set and have that be the input of a geoprocessing service configured in the geoprocessing widget. However, to do this the underlying model or script must be configured in a way to accept 'user defined values'.
This is complementary to article number 000014552 and applies to ArcGIS Pro.
In the end, the Geoprocessing service was able to work based on adapting the themes presented in technical article 000014552: How To: Make the selection set of the Select widget the input of the geoprocessing widget in Web AppBuilder
To have this functionality, the initial input into the model or script must be a transportable dataset. A transportable dataset refers a data type that supports the user defined value input mode.
The following data types are transportable and support the user defined value input mode:
The service can be published and configured in the geoprocessing widget, with the ability to accept user-selected values.
Get help from ArcGIS experts
Download the Esri Support App
