HOW TO
Modify the arrowhead size of an arrow line symbol in ArcGIS Pro
Last Published: July 20, 2023
Summary
In ArcGIS Pro, the arrowhead of an arrow line symbol is a shape marker symbol layer that defines the shape and appearance of the symbol. This article provides the workflow to modify the size of the arrowhead of an arrow line symbol.
The image below shows the arrow line symbol before the size of the arrowhead is modified.
The black arrow line symbol pointed at an island on the map.
Procedure
  1. In ArcGIS Pro, in the Contents pane, click the arrow line symbol to open the Symbology pane.
The Symbology pane.
  1. In the Symbology pane, under Format Line Symbol, click the Properties tab.
  2. On the Properties tab, click LayersThe stacked layer icon..
  3. On the Layers tab, click the arrowhead shape marker symbol layer to modify the arrow.
In the Symbology pane, access the arrowhead shape marker symbol layer by clicking the Properties tab, the Layers tab, and select the arrow symbol layer.
  1. Expand the Appearance section.
  2. For Size, select the preferred size value.
  3. Click Apply.
The modified arrowhead,  which is done by expanding the Appearance section and selecting the desired size value.
The image below shows the size of the arrowhead modified.
The modified arrowhead of the arrow line symbol pointed at an island.
Article ID: 000025908
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
