ERROR
Unable to load the ArcGIS Server backing stores and/or the ArcGIS Server license information
Last Published: June 18, 2021
Error Message
In ArcGIS Enterprise, licensing roles for federated servers can be configured from the Organization tab. However, attempting to configure the server roles fail, returning the following error message:
Error:
Unable to load the ArcGIS Server backing stores and/or the ArcGIS Server license information.
The error message returned when attempting to configure the ArcGIS server settings
Cause
The server's root certificate is untrusted and may be configured without a subject alternative name (SAN) parameter. This can be indicated in the portal logs as an error about the certificate missing the SAN parameter. An untrusted certificate includes self-signed certificates and certificates issued by an unrecognized certificate authority (CA).
Solution or Workaround
Replace the self-signed certificate with a CA-signed certificate.
To generate a new CA-signed certificate and configure ArcGIS Server with the certificate, refer to ArcGIS Server: Configure ArcGIS Server with a new CA-signed certificate.
To configure ArcGIS Server with an existing CA-signed certificate, refer to ArcGIS Server: Configure ArcGIS Server with an existing CA-signed certificate.
Article ID:000025762
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
