PROBLEM
In ArcMap, portal connections are made to share projects and access content from members from an organization in ArcGIS Online or Portal for ArcGIS. A portal connection can be made using the Manage Portal Connections tool in ArcGIS Administrator. However, attempting to add a portal connection in ArcGIS Administrator fails, with the following warning message returned:
Warning: The URL specified does not appear to have a running Portal for ArcGIS.
Depending on the cause, follow these steps:
Allow-list the URL containing portal components
Note: Contact the organization's IT department to carry out the following workflow.
Allow-list the following URLs:
http://<webadaptorhost>.<domain>.com/<webadaptorname>/home
https://<webadaptorhost>.<domain>.com/<webadaptorname>/home
https://www.arcgis.com/home
https://<organization>.maps.arcgis.com/home
Update the portal's password in Credential Manager
Give permission to the user to the machine's registry settings
Computer\HKEY_CURRENT_USER
Get help from ArcGIS experts
Download the Esri Support App
